Kraeuterbutter
Austria
nsta360 - for example - uses another principle completely. There are NO outside moving parts. The surface is completely “clean”. The critter records the camera movement in all directions as well as a 360 degree all directions video (5.7k), which is “extracted/created/stabilized” etc. by a tool, when exported to a standard format (also Apple ProRES, which is preferable to DJI’s in-frame “stuttering/flashing” each 30 frames exact - also when recording 25fps).
It’s a different approach by Insta360, but it works surprisingly well (I have both products), and the Insta360 One X2 is extremely robust and also water resistant (probably not completely water proof for prolonged under water use). I haven’t looked back to the effectively no longer supported Pocket 2. And I like the smooootheee results from the Insta, where I also get the added option to modify the viewpoint up/down and left/right - even between front/back view or anything in between - AFTER recording is done. Sometimes life does not happen quite as you expect, and “the ultra wide all around” view have benefits in these cases.
For the rough and tumble of daily - unplanned - use, I value the Insta approach. It’s compact and extremely robust. The latter is not at all the case for the Pocket 2.
the Insta ONe X2 and the Pocket 2 are complete different beasts..
the image Quality of a reframed Video (or pictures) is not at all comparable with the Pocket 2
the One X2 lacks resolution big-time when you compare videos or even more on images
i like my insta one X as well - but: for image quality not at all comparable...
its nice for funny shots but as soon as you crop in or use a reframed picture quality sucks..
i hope 11k for 360 pictures will become standard soon
and video: even with 8k the reframed video looks by far not that good as a video from the pocket 2
for durability: well..
i always was very carfully with my onex
but one time tipped over, 20cm height -> lens scrached
the lenses are very easy to damage
lens-covers make the image quality (and stiching) even worse
so: the X2 is a very different approche and not "better" than a gimble solution
its strength are on other sides.. image quality is not a strength of 360 cams
