Montfrooij
Flight distance : 2560453 ft
DAFlys Posted at 11-5 01:33
The attitude here is its your own personal responsibility, so if your not vac'd and you get ill thats on you.
Even though I did get my jabs, I think you really can't say this.
Of course it will help a little (vaccination) but I think that 95% (that is not an exact percentage, just for ease of typing) of the people don't need it, as it won't stop people from getting infected or spreading even.
And with the high numbers these days I really think it won't make much of a difference in the longer run.
We have a perfectly capable immune system to fight this. At least most people have.
The other 5% can benefit from booster vaccination, but the rest will be almost as good with or without.
The only difference in the longer run that they have proof of, is the T-Cells, which are trained after a first infection or vaccination.
That helps.
But after that it is not helping enough to make these bold statements based on being vaccinated or not.
From how I see it, you either have bad luck or not. (genes etc.)
And if you do, you need all the help you can get and a yearly booster to keep you system as well trained as you can.
But not for 95% I think it is a waste of resources and not something you can use as the key to enter somewhere.
Clearly, it does not help, looking at the numbers.
