fansfe82067d
I kept the modules separate overnight and both are at 100% this morning. Bottom line is that the user must manage the batteries themselves at the moment. So....
- connect both modules and charge.
- when taken off charge, separate modules
- if you use the camera and connect both modules, you should separate them after use unless...
- if you use the camera module on its own, reconnect the modules so that the camera gets recharged, and when it shows full, separate the modules.
This is, of course, close to ridiculous. How this escaped the notice of the DJI engineers I can't imagine. So I can only conclude they know about the problem and can't fix it, which is a serious issue. |
