Yaman-Python
Japan
I had the 2 events with 2 different firmwares, The first time with 01.01.5.10, the second with 01.01.08.10. It is not a firmware-related problem. That Youtuber cited in the 3rd post may have had a pre-release version of the product, and his problem was different anyway, so if a firmware update may have fixed his problem, it does not fix that reported by me here.
To summarize (read my 1st post for details), it looks like maybe some sweat or invisible wet dirt on the screen may be interpreted by the cam as swipes and touches when the cam is turned on and because the Format function is just 1 swipe and 3 touches away from initial state after being ON, it can happen accidentally. and it did happen once for me, and almost in a second case.
I bought the cam a day after release and used in many tests and about once a week on average in actual hiking activities (2 are on youtube now; if you wish the links, I can provide), so that is a lot of usage. The event (accidental formatting) is a low probability one, however if it happens it is a disaster. In the 2 cases, it happened after the cam had been in my pocket for a while, and sweating a bit from the exercise, though I did not notice liquids on the surface of the cam when it happened.
The solution: bury the format function deeper in the menu. |
