Geo_Drone
Flight distance : 2676129 ft
Romania
hallmark007 Posted at 10-3 09:01
The faster the shutter “Shorter Shutter Speeds” the more noise you will create, so for this mode the ISO is set higher to avoid more noise rather than less noise, and this is quite common in many video cameras. Don’t be under the illusion that ISO is whats causing noise in your videos or photos, light is what causes noise low light to be specific and there are many ways to counteract this in your exposure triangle.
ISO is in fact how bright is the image gathered from sensor...A simple explanation...as ISO increases, the brightess of image from sensor increases, but with it will also increase the brightness of pixels that have no information, so will create a noise pattern (from nothing you cannot get something, just noise).
Each sensor have a size for pixels (photodiodes), bigger pixels = bigger sensitivity = less noise.
So each time you increase the ISO, you induce a noise pattern from sensor as not all pixels have info in order to transmit to DAC for processing...
Technically, each photodiode from sensor is excited by the photons from a light source, creating a voltage...that voltage is sent to a convertor and is processed in order to give you that pixel from an image....if there is no photons, the sensor because is getting hot, will induce a parasitic voltage that converted is giving you one pixel of "noise".
Some smart people say that in fact is about light....of course is about light, as technical explanation shows why...but you can also use ISO increase as a lot of programs knows to find the pattern of noise from sensor and cancel it, giving you a final clear image...and is not like ground filming where you put some lights in order to keep ISO low, drone filming is a total other thing, your light comes mostly from Sun and Moon, hard to find a spot that is having so many light bulbs that you can afford a ISO 100 in night.
So we cannot resume at the fact that noise is not because of ISO...in fact, noise is a result of ISO increase, as you need the image to be brightner and voltage from photodiodes boosted. You can boost ISO not because you have enough light, but may boost it in order to go to a very fast SS in some scenarios and eliminate motion blur in some super slowed down footage, so this is in my opinion why affirmation that "NOISE = because of light and not ISO" is not covering all scenarios. (and some will say: Yes, but increasing light can save your ISO for fast moving scenes! ... well, not entirely true...increasing the light at one point will make your DR to crush, you just cannot say in all scenes: I have a super powerful light, can go to SS 1/4000 now! because you will see that when you get good highlights, your shadows will look like shyt.).
Cheers.
