Can't get a live stream started. Advice?
4682 6 2021-11-12
Aswo1
Tried both FB and YT. Entered RTMP url and stream key per guidance in this forum. Tried different altitudes and locations. No joy. Don't understand the video path from drone to controller to device to 5G towers. Anyone shed a light on this? Thanks.
2021-11-12
MiniManiac
Flight distance : 1474354 ft
you cant natively stream to facebook as it uses RTMPS as the app doesnt support RTMPS only RTMP
for youtube you need at least 50 subs
see this video on how to setup streaming for facebook.
you need to enter your RTMP address and then the stream key which can be found in youtube live stream studio.
EG rtmp://myrtmpserver/streamkey
2021-11-12
Bashy
Flight distance : 2354357 ft
MiniManiac Posted at 11-12 09:50
Are you sure you need 50 subs? When i try from my phone is says to use  a webcam or broadcasting software, doesn't sound like there's a restriction there? I just tried it and i can live stream using the browser so should be ok streaming from the DJI app too, i only have 24 subs
2021-11-12
DAFlys
Hendrik made a guide for setup
2021-11-13
Ant Mac
Tryed all of the above with my mini 4 pro on rc2 I keep getting starting livestream faild check and try again any help please this is for YouTube
2024-6-11
DJI Natalia
Ant Mac Posted at 6-11 04:54
Hi there,
thank you for reaching out.
Does this issue persists when using a different mobile phone? Make sure you have a good internet connection or try switching to a different Wi-Fi network.
Please contact the platform customer service to see if RTMP streaming is supported. If supported, you can use RTMP for live streaming. If the livestream fails or a warning is displayed showing that the livestream fails when using RTMP, it indicates that the platform and the RTMP livestream protocols are inconsistent.
We recommend that you try one of the listed livestream platforms compatible with DJI Fly.
Should you have any other questions, kindly message us for assistance. Thank you!
2024-6-11
chris2007
Flight distance : 1152451 ft
Tonga
this a same issue with me i using dji air 3 with rc2 controller
1-9 01:21
