Mavic AIR 2 Bricked
1634 8 2021-11-13
ibenidze
Flight distance : 96821 ft
Georgia
Hello,
So, I did the firmware update to my Mavic air 2 through the GO app, update said all went OK and drone was flying normally, landed, powered off and now it is not booting, fan is spinning and no gimball calibration or startup sound. it is not even connecting to anything, even DJI Assistant on PC doesn't see the drone.
Is there a way to force it to some kind of boot mode or something so I can connect it to PC and do the firmware update?
2021-11-13
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble that this has caused. Can you please confirm what happened prior to the said issue occurs? Did the unit experience a hard landing before? Also, we're you able to check the app to see if it shows an error message? Please keep us posted. Thank you.
2021-11-14
ibenidze
Georgia
Drone was acting normally, while preparing for take off it prompted for update:
- did the update successfully (while on the ground)
- completed normal flight (took photos etc.)
- landed successfully,
- powered off and stored in the bag.
- next flight it was already dead.
No errors in the app, controller just doesn't see the drone
You can tell that drone doesn't boot at all, it doesn't beep or do the gimbal calibration, you can only hear cooling fans.
2021-11-15
ibenidze
Georgia
DJI Paladin Posted at 11-14 00:12
Is there a some kind of key sequence or procedure to do the upgrade in when drone doesn't connect to PC and controller? (p.s. I am an IT person so I can perform a complex proecudure if needed)
2021-11-17
Savage3006
Flight distance : 156709 ft
The GO APP?? Its the DJI fly app.
2021-11-17
ibenidze
Georgia
Savage3006 Posted at 11-17 05:59
yes sorry I meant DJI Fly.
it doesn't connect to any app on phone, tablet or PC
2021-11-17
ibenidze
Georgia
p.s. not sure why this got moved to general topics, I originally posted it in Repairs.
2021-11-17
Savage3006
ibenidze Posted at 11-17 08:50
How long have you had the drone do you have care refresh if you do I would start a claim with DJI, Hope this helps.
2021-11-17
DJI Paladin
ibenidze Posted at 11-17 03:58
Thank you for your response. We can only perform the firmware update via the DJI App and the DJI Assistant 2 software. In this case, I'm afraid that you may consider sending the unit in for a proper diagnosis. You can contact our support team to start up a ticket at https://www.dji.com/support. Thank you for your understanding and support.
2021-11-19
