Sean-bumble-bee
Flight distance : 15997 ft
Can you post the .txt flight log for the flight?
If you go to the web page https://www.phantomhelp.com/LogViewer/Upload/ you will find instructions for accessing the log. You likely need to copy the log to your computer. Upload the log to that website and post the URL for the resulting page here.
If you do decide to upload the log I would copy all the flight logs to your computer, including the DAT flight logs in the ''MCDatFlightRecords'' folder.
You might also like to read https://mavicpilots.com/threads/ ... alysis-guide.78627/
Since the Mini 2 does not have forward or backward sensors can you post a screen capture of the warning message you see?
With regards to loosing signal at 1.2km, I assume the castle was between the drone and the controller, if that is correct then you likely had several feet of solid rock wall blocking the signal. Do you think that might be a bad thing? I do.
With regards to being 1.2km away from the drone, you may have been able to see the castle but I very much doubt you could see the drone at that distance. That is not a good thing for a new, inexperienced pilot to be doing and likely not legal.
I doubt the castle walls are 100m+ tall, so if their tops are over 100m above the take off point then the castle itself and the ground around it is well above the take off point.
If that is correct then
1) the likely legal height limit around the castle is 100m+ above the ground around the castle.
2) if you had the RTH height set (in the App) to 100m then, for that portion of the flight, it was set inappropriately.
If, for example, the ground around the castle was 60m above the take off point, and using your cited ceiling of 100m, then the RTH height around the castle should have been set to 160m in the app.
That said when the Mini 2 looses connection with the controller it will, providing the failsafe/lost-signai response is set to RTH, "....... fly backwards for 50 m on its original flight route and ascend to the preset RTH altitude to enter Straight Line RTH........"
Depending on what course the Mini2 flew over the 50m of flight before you lost the connection, this could have brought it back into communication with the controller.
With regards to the likes of care refresh, you quote a purchase price for the drone in what may be Australian Dollar, yet have your location as France. If your activated the drone in Australia and would have bought Care refresh in Australia then I think you will find that things get complicated and it isn't really something you can use whilst travelling etc. etc.
In short, unless the log shows something unusual, I think this will go down as pilot error and or inexperience. |
