f_marshall
Hello,
My company recently acquired a Phantom 4 RTK with the smart-controller. I am having issues with the "Units of Measurements". Our company uses imperial (feet) units. Within the smart controller, I have set the "Units of Measurements" to imperial. As one would expect, this changed most of the units from metric (the default setting) to imperial.
This is where I am having issues. While most of the units have switched to imperial, the units have not change for the "Height" field for mission planning (see attached image). This "Height" field still says meters instead of feet. This is not simply a display error on the smart controller. I ran a "2D Photogrammetry" mission the other day with the "Height" field set to 100. I thought I was setting it to 100 ft, but during the actual flight I was getting a height reading of approximately 330 ft on the controller - which is approximately 100 meters. I wasn't sure the issue at first, but after some troubleshooting, I found that the "Height" field in the mission planning was still saying meters.
Is there another setting that I need to adjust to change the "Height" field in the mission planning from meters to feet? Or is this a bug in the software?
Thanks in advance for any assistance.
Frank
Height still shows meters, even though the Units of Measurement is set to imperial.
