Charging Station Battery Error for M300 RTK
17630 24 2021-11-17
COA_M600_PIC
Flight distance : 237162 ft
So, after the latest update on my charging stations I have several batteries that keep throwing a battery error. Has anyone else ran into this issue, and if so what have you done to fix it? I have tried placing the batteries with errors into the drone and turning it on. After the drone is on there is no notification about an error so I try to charge again the error comes back. I have let the batteries drop charge out of the charging station and try recharging them and I still get the error. The company I bought the drone from said several people have contacted them about the same issue but they have not given solid information on how to resolve the problem.
Thanks for the help in advance.
2021-11-17
fans32a25bd4
South Africa
I have the exact same error. Changing slots, all terminals clean but at random batteries starts giving errors. Please help
2021-11-25
DJI Susan
Hi there, sorry for the issue you encountered. We are concerned about the issue and hope to get more information for an investigation.
Could you please help to export the battery log and the log from the battery station via DJI Assistant 2 so we can check further about it?
The DJI Assistant 2 for M300 RTK: https://www.dji.com/matrice-300/downloads
DJI Assistant 2 for battery station: https://www.dji.com/downloads/so ... for-battery-station
Thank you very much for your help.
2021-11-28
DJI Susan
fans32a25bd4 Posted at 11-25 23:52
Hi there, sorry for the issue. Could you please also help to extract the logs as instructed on 3# so we can check more about the error? You can upload the logs to Dropbox/Google Drive and provide me with the link. Thank you very much.
2021-11-28
COA_M600_PIC
I think I finally got the error to go away. It took multiple rotations in the drone turning it on and off and clearing any error that was there. It kind of reset the batteries. Almost worked like witch craft. but I haven't had any errors since I did that.
2021-11-29
djiuser_fY1GSXHsbXE6
Flight distance : 342051 ft
Yes - I have 2 x  battery stations and the second one has this issue now. The first is still fine. Very strange.
2021-12-11
Craig_Tas
Flight distance : 2998255 ft
usually any issues when charging that I have had is firmware being outdated on the batteries.
2021-12-14
COA_M600_PIC
Craig_Tas Posted at 12-14 17:14
Firmware was up to date on both of my charging stations and 16 batteries. there was a corruption in the firmware from a previous update that was fixed during the most recent update. but in the mean time, before the current update came out, I had to insert the batteries in the drone and completely cycle them to 0% charge and reset them. had multiple phone calls with my DJI Dealer and this was their solution.
2021-12-20
Dunmire83
I have a colleague that is encountering the exact issue highlighted by other users above - as it's been a few months, I'm not sure if there is a new resolution that I have missed? Thanks for any help!
2022-2-10
fans32a25bd4
South Africa
hi, issue also randomly disappeared but came back this week. All battires x4 100 charged, when charing them again one battery started giving battery error, and second battery shows fully charged on the battery station yet the heath DJI Pilot apps shows it at 30%. Removed the 2x batteries with issues and bought a new set. charged them together with the 2 working batteries and suddenly one of my working batteries started to give the same battery error. really frustrating and no idea how to fix
2022-3-2
Craig_Tas
COA_M600_PIC Posted at 2021-12-20 06:40
Late reply to you, been so busy I just don’t have time to check all the forums I used to visit.
Looks like we have all been having this issue and I am now updating the battery station and batteries to the latest firmware hoping it has been resolved.
I just have random batteries fully charge but then error.
Bloody annoying!
Hope you have resolved your issues.
2022-5-30
djiuser_vGb9M0v7GPWc
Good morning, i have been reading all the complaints about the errors with batteries and the charging station. I was particularly interested in what firmware update was corrupted and how we can see what firmware update we have now ….i finally got my m300 battery charging but its partner is now no longer charging at all (not recognizing it at all)
These batteries are not even 9 mos old…any thoughts and how can i see what latest firmware i have and which one was corrupted
Thanks
Hepner
2022-9-23
COA_M600_PIC
Craig_Tas Posted at 5-30 14:25
I'm still having the issues after multiple firmware updates. not sure if its an inherent flaw in the tb60s or not. Currently out of 16 batteries that I have only 2 of the are throwing errors. I just do the same thing over and over until they reset.
Cycle battery to 0% charge ( Helps if you set them in the drone with a known good battery).
Once battery has cycled to 0% check firmware then try charging again. sometime it works with the reset and sometimes it does not. just a practice of futility at this point.
2022-9-23
COA_M600_PIC
djiuser_vGb9M0v7GPWc Posted at 9-23 06:58
Unfortunately I don't recall which firmware I had that started the issue. To check which firmware you are on simple connect your controller to the battery charging station and go to the HMS tab on the controller. The firmware I'm currently at on my batteries is 01.02.05.44.
Another test you could do is one that was recommended to me. insert both batteries ( one bad and one good) into the drone and power it up then go to the HMS tab to check battery health. its possible like with other types of batteries that there could be a dead cell in the battery. Hopefully with cycling the batteries through your drone will "wake" the battery up and allow you to charge it, I've had to do this many time with multiple of my batteries.
Hope this helps.
COA
2022-9-23
djiuser_BTW242gjDNO5
Norway
Have a brand new Matrice 300 RTK just in.
Activated chargingstation and set about to charge 4 batteries + controller battery for the first time. Firmware at latest according to controller.
Two of the Matrice batteries throw red error LEDs with 3 loud beeps.
These batteries does not have any charge on them according to the LEDs on the batteries themselfes.
2023-3-1
COA_M600_PIC
djiuser_BTW242gjDNO5 Posted at 3-1 04:49
You need to cycle the ERROR battery in the drone with a good battery to RESET the ERROR. I know it sounds like witch craft but this is was told to me by my DJI tech guys and dealers.
Put one bad battery in with one good battery. turn everything on check for updates. refresh firmware if able. (this process may take a few time to stick.) If you have enough charge leave the drone on for a few minutes and run the battery down. then try charging again. if error occurs again rinse and repeat. its a prosses of futility.
2023-3-1
Manraj Govind
Mauritius
Hi,one of my battery previously showing error when charging, after some matching with other batteries.,it was good..then suddenly error appeared again and now nothing not even the error...when put in drone...it showing N/A and no indication light appeared on the test batteries
2023-6-19
DJI Paladin
Flight distance : 318 ft
Manraj Govind Posted at 6-19 23:16
Hi there. Thank you for reaching out and we do apologize for the inconvenience. Can you please confirm what specific DJI product are you currently using? Are you currently using a Professional product or a Consumer drone? Please confirm. Thank you.
2023-6-28
djiuser_jkUTyeKiFCGw
Sweden
The error occurs when you do "hot Swap" to fast. The battery needs to handshake with the AC .
2023-11-6
djiuser_zm2hq1P2FsJI
How do you drain faulty battery to 0, as when the batteries are unbalanced, the rotors won’t fire up. If I just turn the m300 on, it shuts down after a short period
2024-1-4
AR_AirPrecision
Flight distance : 2683589 ft
Belgium
djiuser_zm2hq1P2FsJI Posted at 1-4 03:35
Charge to 100% then discharge bellow 10%. If you can't even charge it, then the battery is good for recycling. Lifetime is approx 2years so TB60s are slowly dying, we just lost 2 pairs.
And those weren't even giving issues in Pilot2...only not safe to fly according to our ops manual.
ps: battery maintenance is described in User Manual.
2024-1-4
fansb8dd230a
Flight distance : 71365 ft
I would like to buy a non-working battery for my project - dji battery killer. Write please PM to me if you have one for me.
2024-2-11
Coskun_Ertugrul
Turkey
Switch on the BS60 battery station and check the circuits on its main board. Probably a few of them are burnt out or there is a contact problem. Then check the thermal paste of the processor of the motherboard.
The room is old and has lost its properties. Replace it with a quality paste. Your red audible warnings at the battery station will improve.
Of course, these operations are out of warranty. If you have a warranty, fix this problem from the warranty. Otherwise, if you are confident, you can try these.
2024-8-25
rrichey
Flight distance : 572818 ft
Hi all, we have just recieved our new Matrice 300 which has only a handfull of hours on one set of batteries. The other set when put in the unit has had no cycles at all and came with 8% charge.
It comes up with an audible error when plaace in the charging unit. I have updated all firmware and plugged the remote into the box charger for updates. I read here about discharging to zero which we have completed but the batteries would not turn off as they should in the unit. Hold once hold again the power light goes off but batteries still blinking away....
They are both still on blinking 1 green bar  with zero charge and I cannot turn them off to try and recharge them, any body else have this same issue. Looking for assistance please.
2024-12-7
LV_Forestry
Flight distance : 4726654 ft
Latvia
rrichey Posted at 12-7 00:26
Discharging a battery to 0% is the worst thing to do.
When the battery refuses to charge and the charger beeps, often all you have to do is put the battery in the drone, turn it on, let it do its init. and then turn it off.
And if you just got the drone, it's probably not new. It's been at least a year since the M300 batteries have been off the market, you can only find the M350 ones (which are compatible).
It's a safe bet that the owner didn't cycle the batteries every 3 months as recommended.
2024-12-7
