Fabrizioooo
Flight distance : 3312001 ft
Hi !
A major feature that was used in the Mavic 2 Pro was the "HQ" mode that cropped a 4K image into the full resolution of the sensor, so it produced a little zoom with an equivalent of 33mm focal length and gave a very cinematic results, and gave better sharpness results in far away objects.
There is no more this mode on the Mavic 3... except in 4K120, which also record 4K resolution by cropping into the 5.1k full frame, and give an equivalent to 33mm.
my drone is on my desk, not flying, shooting at a building far away. First in 4k25, then 5,1k 25, and then in 4k120. The logic would be that the building will be composed of more pixels in the 5.1k footage, but... its not.
Here on the 4k25, the building is composed of 393px.
on the 5.1k footage with an equivalent focal length of 24mm, the building is composed of 523px. better !
Here is the footage of the 4k120 with an equivalent of 33mm :
the building is now composed of 587px, 64 pixels more than the 5.1k, 12% more.
This is caused by the fact that, with this crop, it use exactly 3840x2160 from the sensor so it have a ratio of 1:1. When recording at 4k25, it takes the full resolution and then merge pixels together to reduce it to 4K, so it loose details on the process...
You can also notice that some of the little branches in 4k25 are very thin, almost disappear, but more visible on the 4k120 as they are composed of more pixels.
Please DJI, add a 4k25/30/60 fps option with the same logic as the HQ mode on Mavic 2 Pro, a 4k crop in the 5.1k full frame that give an equivalent of 33mm focal length !
