Rustic17
Flight distance : 2733760 ft
So I'm flying my drone off the Big Island of Hawaii and getting some good shots of surf, rugged volcanic coastline, and blue-green water when I get a Caution for traffic. I descend to about 5 meters over the water (just where I can see it above the horizon) as I start to hear a helicopter approaching. The alert becomes a Warning. I see the helicopter approaching and it is 200-300 meters above the water and will pass directly over my drone. The alert becomes a Automatc Collision Avoidance (I think) repeated constantly until I land the drone and finally turn off the iPhone. As this last alert triggers, I looked up to the helicopter and when I look back to the drone it's out of sight. I immediately think maybe Automatic means the drone is trying to avoid the helicopter using built in software I'm unfamiliar with and since I can't see it I'm thinking it is descending into the ocean. I immediately give climb input trying to avoid splashdown and knowing the helicopter is way past and I'm no threat to it. Still out of sight and with Automatic Collision Avoidance blaring, I point the drone to the RC symbol on the map and head home. As previously noted, I land and turn off the drone, then the RC, and it's not until I unplug the phone and turn off the Fly app does the alert cease. Now for my question: What happens when Automatic Collision Avoidance triggers??? Is the drone programmed to fly some maneuver like perpendicular to the conflict aircraft's flight path??? If not, the last alert should probably be Maneuver to Avoid Conflict in my opinion.
