Bashy
Flight distance : 2354357 ft
One other point, if you use the Flight attitude indicator on the bottom left, its the Radar type icon screen thingy.
When the aircraft is a distance away, when you're aligned correctly you the controller will add a green arrow to the icon, once you then line that arrow exactly to the direction of the aircraft then that is the best signal you can achieve horizontally, you then just need to worry about vertically, and at that distance of 1km, you need to 120m (400ft) high and the controller nearly level with the horizon, but you can slowly adjust a little, then check the signal icon at the top, keep an eye on it and you can achieve the best signal, ok its long winded, I'm sorry, but that's how i manage to get the best i can get out of it and my friend has managed 5.5km ;) |
