David-Air
Flight distance : 4717963 ft
Hi all
My old controller was broken a few months ago. I purchased a brand new Mavic Air controller. I noticed for the past couple of flights when I use the camera scroll wheel which meant to scroll the camera up and down, instead, the air-craft sway left and right. I can still use the screen to scroll the camera but obviously not convenient. I then calibrate controller and I notice the scroll wheel will induce movement on right stick left and right percentage. What I did was to calibrate the controller mulitple time and eventually it work fly perfectly. However, once I swap out a new battery and it issue comes back again. Again, I recalibrate and works again. Very weird!!! So I thought it may be the firmware.
My next step was to use DJI Assistant 2 and downgrade the controller firmware to the lowest versions, then connect to the drone. Start DJI go app and let the app to upgrade the latest firmware. I was hoping it will work, again work a little while and the issue will return.
Anyone has the same issue. Does anyone has remedy for this?
Thanks in advance
