Nicodema
Flight distance : 90259 ft
Tornado12 Posted at 12-9 08:57
Sounds like someone needs to set up a controlled test indoors, under controlled light. Under a controlled testing environment I suspect you could learn a lot about this. I haven't noticed this issue with my mavic 3, but I havent looked super hard at it either. Someone mentioned the front arm LED's could be a possible cause and I think that is a very good theory and could easily be tested. Perhaps it only occurs under certain color grades. Photographing some color boards in a controlled test could help reveal this as well.
One owner did post some pics of a fairly reasonable test setup, grey boards or some such, but a uniformly lit white sheet would be an interesting acid test, with and without LEDs covered/disabled for good measure.
The magenta edges seem to be larger on the right edge than the left, and are very subtle in the unmolested images. Adobe Dehaze seems to really accentuate the issue, especially at 80 and above.
I'm impatient to see if DJI's predicted software fix does iron it out. I suspect it may well do, as it does appear to be quite deterministic. |
