DJI Wanda
Hello, there. Sorry for your inconvenience. Would you please check the things below and tell us your feedback?
1. Check whether the Fn button has been stuck?
2. Check the Control - Button Customization to see whether you set the Tap to Recenter Gimbal.
3. Could you please try to link the aircraft and controller through the method below and tell us whether it works?
Method: Press and hold the "Customizable Button" on the upper left corner, the "Photo/Video Toggle" on the upper right corner, and the "Shutter/Record Button" on the top panel of the remote controller for two seconds simultaneously. When the remote controller is beeping, and the battery level LEDs on the remote controller are blinking sequentially, you can start linking. |
