UAmetry
Geebax Posted at 12-1 12:53
Yes, that is jello alright, it is caused by the camera vibrating. The trick is to set up with the camera pointing to a surface, but without the motors running. If you get jello when the motors are off, then it is the gimbal vibrating. If you get jello when flying, then most likely you have an out-of-balance propellor. Try changing yours props.
Thanks for the info Geebax. What does "set up" mean? Is it just turning on the controller and then the copter?
I will definitely try changing the props and see if that makes a difference.
Thanks again,
CJ |
