Depp
Flight distance : 1868796 ft
Hi. You need a drone with the DJI Air Unit (lite) or the Caddx Vista. These can be configured as a "PNP" that flies with the DJI FPV controller (around 300 $) or at an additional cost of maybe 10 to 30 $ with another transmitter. If you go that road (additional transmitter) you buy a different controller, not the DJI one, starting around 100 $.
I went the DJI road with a GepRC Cinelog 25 HD (which is great) but if I had to start again I'd go with the same drone but with TBS crossfire and a different controller.
Pro DJI: very easy to configure, pro non DJI: more options, a bit less expensive, in some cases more range/penetration. So if you lose video signal you probably still have radio signal and can push the drone up to maybe regain signal. Though I have to admit that I haven't flown with another controller yet.
There also is the possibility of getting an analog receiver for the DJI goggles. Then you can fly cheaper analog quads for practice. Haven't tried that either.
Good luck!
