Montfrooij
Flight distance : 2560453 ft
These terms are a bit confusing (and originated in a time long before digital video).
30fps is 29.970 fps. So that is correct.
There is a reason behind this, but I have forgotten why (you can find it easily online).
From what I remember is that Pinnacle does show 30, but it is 29.970.
Main thing to remember is that you (at least in Sweden) are in PAL area, which means it is 'best' to shoot in 25 or 50 fps.
That is most important when you have artificial lighting in your footage. It can start to flicker if you shoot at 30fps. (or 60fps) due to the frequency of the grid.
The other reason that could be valid is if you want to combine other footage that was shot with a 'PAL' camera (25 or 50 fps) and you want to combine it.
You could slow the 30fps footage down to 25fps to avoid frame skipping, but that could not give the desired effect.
If you shoot during daylight (no artificial lighting), you can also shoot at 30fps of course, but that footage might be harder to combine with 25fps footage.
One final consideration, you could also opt for 50fps. That (sometimes) is less prone to 'stuttering' because the difference between frames is less big when moving.
Make 100% sure you edit in the same framerate (so 25 - 50 OR 30 - 60) as you shot your footage. Otherwise it will also introduce frame skipping every x frames. That results in ugly jumps in your footage which makes it less smooth.
