dr6583
Flight distance : 490627 ft
AntDX316 Posted at 12-13 01:11
The #1 rule of setting RTH higher than everything in your flight path was not done. It's a rule that everyone should know but unfortunately isn't taught to everybody. Having the 400ft law prevent you from not being able to set the RTH correctly made you crash. If you are scared about breaching 400ft then fly where you can see it and ensure that anything near is not taller than 400ft from your take-off position. I try to teach everyone this when I show them about drones. That is the #1 thing to always do besides updating all the firmware, doing all the calibrations, and ensuring you have GPS signal. I've had jobs where I had to do them without GPS and it is stable but this is because there is little to no wind in the areaI'm flying, I can see it, and I feel confident it responds to All my intents.
I always set proper RTH when in the air (flying as high as the tallest obstacles and setting Higher). I also ensure to know what the failsafe procedure is when the signal is lost, RTH, hover, land. I change them depending on what I'm doing. If I'm flying under trees, you should not use RTH or it will crash into the branches above. If you are over water, you better not set land unless you are on a boat. It's so common sense to me but it's 100% understandable when people new to the activity don't know how things should be done. The logic is good though, not breaching 400ft AGL but ultimately that screwed you. Who knows if there is an on-going investigation to find the pilot that caused damaged to what it hit.
Indeed. I check, double check, and triple check all the settings in the Safety menu twice. The first thing in pre-flight, and again the last thing just before takeoff. |
