Montivette Posted at 1-25 14:50
I will go fly over an ice frozen lake with no obstacles for a mile ahead to test whether OA is doing what OA is meant to do as it sees trees ahead in distance triggering it to rise to clear them and sometimes rise 120 feet over tree top.
Note in prior video #2 in this thread (December firmware) Test 1 started at 126 feet and ended at 179 feet. Not too many trees up there for OA to avoid.
Does your craft hold altitude when hovering over the snow ? If it does then vision and OA sensors on bottom of craft are working fine and you can eliminate them as the problem . If not they could be the problem. From what I see this is a caused APAS and BYPASS.
Edit: Ok had a look at 2nd video and in that video its very clear vision sensors are working as they should. Your craft at hover is very steady. So you can eliminate them. If bottom OA was causing the problem then craft would be beeping or raising up. If you look at page from the manual I posted it clearly tells you that you could have problems "Using APAS" in snow and or very bright light. Once you turn APAS off everything is ok, so it looks like APAS/BYPASS is what's causing your problem "Or the conditions you're flying in"
I think because one poster came out and said I quote "
"its 100% an issue with the downard facing vision sensors. Something is throwing them off" . which was 100% wrong looking at how vision sensors were working and this is what completely threw me. Also if this was the case then you would have the same problem with brake mode, and you don't. |
