Sean-bumble-bee
Flight distance : 15997 ft
Unless you backed them up to computer or synced them with dji etc. then they are likely gone, sorry.
BUT
What did you do to delete them?
If you deleted only the .txt flight logs then you may have left the DAT logs on the phone. They are perhaps not as much use as the .txt flight logs but depending on why you want the logs they may be of 'some' use.
Also, check the mSD card from the drone. When the card is attached to a computer there should be a folder called MISC, open that folder then open the folder LOG, then open the folder flylog, in there there should be a file named "fc.log.log ", that is not a typo, it is likely to be around 512Mb in size.
If you find it, make a copy of it on your computer then change the name of the copy to fc.log.DAT
The likes of CsvView and DatCon running on a Windows computer may be able to read the DAT, it can take a LOOONNNGG time to 'open' the DAT with CsvView (if it succeeds) but DatCon was quite quick on the one I just tried. |
