Mark The Droner
Flight distance : 2917 ft
The GPS location map is simply showing the location of your Nvidia Shield K1.
I have 2 P3Ps and fly both with an Nvidia Shield K1. But I've never had a problem like you're having. Your screen is showing good signal strength up and down and seems to be showing good satellites too, but nothing else. It's been so long, I can't even remember how to connect or bind or if I even ever had to. When I set up to fly, I first turn on the controller and the lamp on the controller is red. Then I turn on the P3P. The lamp on my controller then turns green before I've even turned on my K1. The lamps under the wings start off yellow flashing, but eventually turn green flashing - but it takes a minute or two. But this would happen even before the Go app has been loaded. My K1 starts up. I enter the main screen of the K1. I plug in the cable into the K1. The go app usually loads automatically. Then I'll eventually get the screen that indicates I have a P3P and so I choose "Camera" and then the normal flight app screen loads. I've never tapped "Camera" and seen a grey screen such as yours.
Since you have both up and down signal strength indicators appearing to be reading excellent, it seems you may be right about it being a hardware or cable problem. Unless, of course, we're looking at some kind of default screen. Your camera tilt indicator seems to be working?
Sorry I can't help you.
Good luck. |
