Bashy
Flight distance : 2354357 ft
Just watched most of the video, up til the point when you gained control, what i can see is a drone out of control from the wind, granted, it doesn't explain why it gained the height it did, but watching the stick movements and the m/s and the flightpath, it all looks like a wind issue, when there was no stick input, the drone was moved backwards and upwards, looking at the flightpath, it really does look like it was pushed backwards and only when you lowered it considerably did the drone then start to go forward, you should have put it into sports mode. You say it was only 6m/s max gusts, that would have been at 10m, it could have been considerably more higher up and the higher it went, the winder it would have become and as it was in P mode, it got blown backwards. It looks like you dont have a lot of flight time under your belt, so you made a rookie mistake from the get go and that was having the wind at your back when flying out, therefore making more difficult on the homeward journey because you then have the wind against the drone.
As for the privacy issue, I'm not sure what the issue is, to be honest? unless you're hiding from the feds lol If you want a fully informed analysis, you have to provide the full flight log, else its all pretty much guesswork based on snippets. Follow the instructions on the phantomhelp to upload the log and if you prefer, just PM the link to either Labroides or JJB* or both then its not in the public eye and they will help you |
