edwardquan
cpt_carrot Posted at 12-27 11:06
4k @ 24/25/30 fps according to the camera menu. You can probably get higher depending on conditions (moving vs stationary, inside vs outside, ambient temperature, etc). Using a battery/screen module also helps.
Indoors, I get 42 min at 2.7k 24 fps before the lens module runs out of memory without overheating.
Thanks for this info - I will have to do some experimentation.
The issue is I wanted to use the Action 2 both as a webcam and as a CCTV camera - the latter which would need to be ONVIF compliant. I can plug it in permanently to my PC and use it as a real time cam, but obviously don't want it to overheat etc. |
