Xavier1984
Flight distance : 1579088 ft
Switzerland
Charles Adams Posted at 1-1 12:55
Shows what I know (and don't know). I thought D-Log was equivalent to RAW. Apparently not. And the provided LUT just converts the output to rec709. Still, it's a better format to work with than the "normal" output, is it not? Or it will be? Hi, raw is raw footage like raw image, uncompresssed format, with full possibility of post treatment.
The dji lut is a good start. Yes in rec709 space it is better to grade as generally you will deliver the video in this space. The dlog footage give you manually or via a lut the chance to obtain the max of the dybamic range of the video so it will be possible to use the max of the shadow and the highlight. You have too more possibilities to adjut the exposure. When these steps are done you can tweak the color to give a look on your video. There are 2 differents steps (and many more if you add some visual fx, denoise, sharp, stab etc..).
With nornal mode the clipped highlight are not recoverable same for the shadow so the dlog formst is a big advantage but it is very more complex to deal with |
