JJB*
Flight distance : 12225059 ft
GaryDoug Posted at 1-1 15:03
Apparently neither does PH. I see the same thing there. Neither shows stick movement at those times. Both show Go Home at a later time than I was referencing. They are pretty much identical. Or do you mean that PH fails also?
Now to get back to my question, why do both sites show 30-40 mph speed and no change in the HP distance figure? Are they both showing the vertical speed included? Because it is falling fast.
Hi Gary
Last 4 records in the log are duplicates, showing the same values.
Before that distances between 2 records, calculates using GPS data, same distances and correct speed values as before in the log.
6.8 meter for 12m20.2 and 12m20.6. GPS data records before that are changing.
Max speed 17.1 m/s = 38.3 mph.
Speed is always the horizontal speed, calc from the X and Y axis moves of the drone.
Speed data in the CSV file correct, not so correct after the incident in air.See how the GPS and YX speed lines starts to diverge. (GPS speed done using LatLon data over time)
See also my previous chart in wich you see the curve it made dropping down, a smooth line wich means that GPS data is correct.
Just before the falling down RC input stopped, before that fwd pitch + some left yaw and up steering.
2 seconds later the steady heading changed from 184 to 153 to 262 to 156 than only to the right for few moments.
My guess bird hit or prop/propulsion fail on 1 motor.
If it was a bird than it seems logic for the M3 to correct first, prop damage and circling down. BUT i can be totally wrong ofcourse....
cheers
JJB
