Burstmode
Flight distance : 258379 ft
Perhaps there was a relatively strong downdraft over the cliff out powering the cene mode climb, maybe sport mode would have been able climb.
There was no significant wind, and no downdraft at all (at least that I could tell). Worth noting, I think: it climbed perfectly well, as it always has, from sea level almost all the way up until it reached approximately "0" altitude. After that, it would not climb appreciably (it gained then lost a few feet towards the end, but it was not responding to Up stick as it normally does).
It was in "Normal" mode the whole time (I only learned yesterday, on this forum, that the flight "Mode" setting on the controller makes no difference, it only sets the mode to what's requested on the controller if you change the switch while the drone is in flight...or so I am told. I switched my controller to Cine mode after my first few flights last summer and have not touched the switch since, but as I now understand how things work, it apparently has actually been in "Normal" mode all along). Maybe switching to Sport mode would have helped, I don't know.
Maybe a bug or max altitude reset if you recently updated the fly app? Looks like two others have had similar experience
Yes, I *did* update the app (and also firmware) shortly before going out to fly it (less than an hour before this flight).
Yes, I saw the other posts from people who reported something similar...similar in some ways, but not identical. I believe my case is the only one posted where almost the entire flight was at "negative" altitude, over much lower terrain. But it does seem interesting that the failure to respond to Up stick commands happened after the Mini climbed UP to roughly "0" altitude (I believe that is also true in one of the other reports, and it's sort of an "edge case" scenario, that probably wasn't tested exhaustively...most flights don't involve negative altitudes).
I am hesitant to call something a bug -- I don't know enough about the specific technologies in the mix to make a judgement. I'm still very new to this. But reading those other two threads certainly does make me go "hmmmmm..." What I do know is that I was on the Up stick hard, and for a long time, and it was not gaining altitude. This was so different from my other 60+ flights, where UP stick always made it immediately zoom higher, and very quickly. This flight experience was completely different. I could tell something was different (it was not responding to a basic control input), it seemed something was wrong, but I had no idea why it would not gain altitude when I pushed UP stick all the way for so long. Of course, as it was happening, I had no idea what the cause could be, I was busy, focused on getting it back to a safe landing place -- though ultimately, that was not successful. As the title of this thread says, my initial guess was that it was just too cold outside. I'm sure that didn't help (batteries don't like cold) but now it seems there may be other factors.
Cause and Effect, or just a coincidence? I do not know, and frankly I am not qualified to make that call. It is an interesting speculation, but at this point, it's just that -- speculation. Anyone who has tried to troubleshoot issues in complex technology knows that one must be careful about jumping to conclusions. Still...it sure is interesting.
