Sean-bumble-bee
Flight distance : 15997 ft
The video appears to show you moving the joysticks in a mixture of crosses,+, circles, o, and then X's, Is that correct? The X's, if done, were very well done as they look to be on perfect diagonals, is that correct?
If your stick movement were as described above then I see nothing wrong with the controller and I am at a loss to explain why the drone went haywire.
My suggestions, reduce the maximum height limit of the drone significantly, that hopefully would prevent it going so high and the problem occurrs again, stay close to the homepoint so that the height is not needed until you regain confidence in the drone - id you do regain confidence etc.. If needs be you can reduce the height limit whilst the drone is in flight.
I experimented with this with either a Mini or a Mini 2 and if the drone is above the new height limit then the change will cause the drone to descend until it is at, or under, the new limit.
Perhaps try some indoor flights and see if the drone climbs uncommanded or tether the drone with some light, strong string but do that in an open space devoid of trees and wires and attach some spaced out paper clips etc. to the tether to ensure that the tether descends when the drone does. You do not want the tether descending more slowly than the drone otherwise it may foul the props. If you tether the drone keep to pure movement above the home point, a tether that snags on something on the ground could cause the drone to crash.
I would also see if you can find some one else with a mini 2 and, if they will let you, use their controller on your drone to see if the problem lies in the drone. Or look for a second hand UNBOUND controller on the likes of ebay if ebay exists there.
