Bashy
Flight distance : 2354357 ft
From what i can gather, whilst items may run ok, the constant fluctuation in the voltage can ruin the item over time, so the life of the item will be reduced, by how much, i aint got a clue and would prob depend on each item, having said that, i don't think a 12v invertor would be too much of an issue, its when it comes to generators is when you should be concerned., looking at that item, it says up to +/-10%, this quite a big jump, but again, prob not enough to worry a charger. I know the UK is 240v and we run 220v items, but the difference there is its a constant flow, where in a car it can be up and down depending on the revs (its its running) If it was me, i would use that inverter to charge it but then i did my my 3rd party charger purely for the benefit of faster charging, so instead of a 18w charger, me got a 2x 30w charger |
