Charles Adams
Flight distance : 3821312 ft
KlooGee Posted at 1-16 14:52
In most scenarios, I'm not a fan of the concept of the bypass feature anyway. I want the drone to go where I want it to go and not fight with it like a toddler. This is also one of the reasons why I'm not a fan of the Skydio 2. It is always a constant fight with getting it to do exactly what I want. At least with the Mavic 3, we've got the option to Avoid, Brake, or go full Crash mode! The Skydio only has full Toddler mode!
My primary use case for "bypass" is one that I hope to never need. Should there be a disconnect from the RC, I'm a fan of the promised functionality of the "smart RTH". I must stress, I'm NOT a fan of how it behaves now, just how it SHOULD behave.
I can see others having a huge reliance on "bypass" for some active tracking, but again, this is more about the promised behavior and not the current/actual behavior. I might use "bypass" for active track if it gets under control.
I'm with you though, in that I won't use "bypass" for manual controlled flight, and I don't use RTH except for emergencies. |
