ivanator007
Rud Posted at 1-17 11:25
HI ivan,
However, I'm still not getting an image on the app or the touch screen on the RS2. your raveneye have to show you a green led when everything are ok (connected to a devive with wifi). if led is Blue there is wifi connection problem with your ipad.
I've trid both cables - usbc to usbc and usbc to the control ( think that's what it's called?) and still no transmission of image to the app. plug usbc from ronin (first one on top) to usbc port on Alpha1. Hdmi from raveneye to A1 HDMI port.
Rud Hi
Is there a paricular order that the equipment needs to be switched on? eg, RS2 then Camera then raveneye?
Ok, resopnses:
HI ivan,
- I've never had green, only red and blue. It seems on the iPad that I need both wifi and BT on at the same time for the wifi to remain connected.
- Done - And I assuem the usbc form opposite port to the bottom usbc slot correct?
Just a note to say I'm using the iPad and not iPhone. I have a galaxy but the app on that can't find the the RS2 or Raveneye. firstable you have to see on the ronin's screen what A1 output so in
- Does the RS2 screen come on automatically? it's not happening with the new settings below.
menu:setup;external output; hdmi resolution auto;hdmioutput settings: rec media dur hdmi on; output resolution auto; time code output on, rec control on; hdmi info.disp off; ctrl for hdmi on.
Do you think I need an iPhone? firstable you have to see on the ronin's screen what A1 output. If not there is another problem to resolve before try to connect on your external device.
Are you connecting your A1 and can see video through the app? i have A7SIII everything run very well on samsung note 9
I thought you had the Sony A1 no? DJI say there's no compatibility. |
