fans7b31ce1a
Flight distance : 4141345 ft
Buzzyone Posted at 1-20 13:57
I am assuming you're referring to the RC Pro or the Smart Controller, they are the same.
I measured them it was a fair bet they would be metric, only you guys doggedly stick to the imperial system ;-) and M4 fits perfectly.
No worries, I swing both ways. Back in the day you could get away with using standard only but no more. Also the depth as measured is approximately 11mm or about 3/8 inch (imperial...) I ordered some M4 Male Thread Machinery Shoulder Lifting Ring Eye Bolt Here's the link just in case all you need are the bolts
https://tinyurl.com/2p8pc4w4
I will receive them tomorrow and will follow up in detail as to if they work or not. Cheers! |
