captainreynolds
Flight distance : 174101 ft
KlooGee Posted at 1-23 19:47
It is late at night for me, so I've not had a chance to fly this yet. But based on looking around in the new app while connected to the updated drone, this definitely adds a bunch of missing features that were absolutely needed and fixed the interface for a few things.
However, we are still missing several things that I think are still key to being able to take full advantage of the hardware in hand:
"Pro" mode for custom exposure on the 7x would be huge. DLOG would be even better at the very least if we're never going to get ProRes support on that sensor (which I realized was never promised) AE Lock just doesn't cut it, is a pain to manage even by adjusting EV compensation using pro controller buttons. Additionally, I think the 7x camera should have its own totally separate set of gimbal sensitivity controls. It also should have its own completely dedicated section in the "Video" section of the fly app (like "Normal" and "Slow Motion" where it will still allow you to zoom, but not zoom down into the 4/3rds sensor.
Would love to see additional sensitivity options for the RC Pro controller a la DJI Go 4 had - we don't have enough now.
Hoping that this FW also fixes the transmission/receiving issues with the drone disconnecting from the RC Pro at any and all distances when using the "dual-band" transmission setting, or using 2.4GHz. I had set the controller only to 5.8GHz to fix this, even when operating in a clean "interference-free" area in the middle of nowhere. I will have to find a wide open space to test this out as it is super disconcerting to test dual-band/2.4GHz spectrum on this drone as you never know when it's just going to totally die out on you.
Also just to note for those asking - USB mode just makes the drone turn off everything but the main computer so it uses less power when mounted to your PC.
It's very interesting - as an 8 year customer, this is definitely the first time I've seen DJI release a "beta" software version of their drone (without directly calling it a beta). It was clearly unfinished software, obvious from the first time I used it. Just these first 10 minutes testing out the new update it is much more polished. Keep working DJI - you're not nearly ready with this one!
