djiuser_PTdhJS3SKm9k
Zambia
Panph Posted at 1-24 23:33
could you confirm you have elevation gaps between different streaks? i mean, if you make a cross section, after the streaks alignment, do you have "jumps" in the model or not? Because as we can see from you screenshot, i cannot recognize "model errors" but only the reflectivity index that is different between the paths. This is normal. The reflectivity index depends not only from the materia of the object the laser are hitting, but even from the angle. The laser, hitting the same object from different angles could give different reflectivity index.
Hi Panph
Thank you for the response. Yes there is definitely a jump at the edge of the pass (image and profile attached). In your message, you refer to "streaks alignment", is this a post processing task.
Thanks again.
