DJI Stephen
Hello there domsterdare. I am sorry to know that you are having issues in calibrating the sensors of your DJI Mavic 2 Pro and thank you for reaching out. Kindly please try to calibrate the said DJI drone using a monitor display of 14 inches or bigger is recommended for the calibration. Please set the display’s resolution to the recommended default value. ( Usually, the 14-inch display’s resolution should be set at 1366*768 or 1440*900. The 17-inch display’s resolution: 1366*768 or 1280*720. The 19-inch display’s resolution: 1366*768 or 1440*900. The 22-inch display’s resolution: 1680*1050 or 1920*1080. The 24-inch display’s resolution: 1920*1080 or 1920*1200.) Thank you. |
