DJI Go crash on start up
5125 10 2022-1-30
67Mike67
Flight distance : 14623 ft
Sweden
Hi!
I have a Osmo mobile 2 Connected to a Samsung S20 With android 12. And today when i started the app DJI Go it crashes right away and now  i can't use my gimbal with the DJI GO app. I uninstalled the apps and reinstalled it again still crashing on start up, so now I want some help I'm sure more people got the same problem.
Best regards Mike
2022-1-30
DJI Stephen
Hello there Mike. I am sorry for the trouble this has caused and thank you for reaching out. Kindly please try using a different recommended mobile device to see if the issue will persists? Upon checking the said mobile device ( Samsung S20 ) that your are using on your DJI Osmo Mobile 2 and with the DJI Go application. I am sorry to say that the said mobile device is not recommended for the said DJI application. DJI would suggest using a recommended mobile device for the DJI Go  application for compatibility and reliability purposes. There is a possibility that the Samsung S20 will be able to work on the DJI Go application. But however, since it's not yet optimized with the said DJI application we cannot guaranteed if it will work all the time and if it will be able to run all the functions of the DJI Go application while using it. For reference I will post a link where in you can check the recommended mobile devices for the DJI Go application ( https://www.dji.com/downloads/djiapp/dji-go-3 ). Thank you.
2022-1-30
67Mike67
Sweden
DJI Stephen Posted at 1-30 19:04
Hi!
So u mean that i will not be able to use my gimbal with samsung S20, that sucks it means that everyone with a samsung after S10 cant use the osmo mobile 2 with samsung because u dont upgrade the app. One more question, what app can i use to get any of your gimbals to work with S20 or S21.
Best regards Mike
2022-1-31
djiuser_9ygT5NblXwbh
Same thing here. Galaxy S20 5g. Dji Go insta crashes. It's ridiculous for DJI to tell their users to switch to a different device. Samsung being the worlds main producer of Android phones and the Galaxy series usually being very near top of the line DJI needs to fix this ASAP. PLEASE REACH OUT TO US DJI TO LET US KNOW HOW YOU ARE GOING TO MAKE THIS RIGHT.
2022-1-31
67Mike67
Sweden
Hi!
Straight on question, are u going to fix the app so I can use it on my Samsung S20?  or if I change to s21 or s22 do I have to buy another brand of gimbal. I think its very bad that u can’t fix the app so it works with Samsung s20 and up.
Best regards Mike
2022-1-31
djiuser_10C87CiYzWTX
Flight distance : 4006 ft
Galaxy s10 here and the dji go app doesn't stay connected I have to sighn in every time I close the app.I don't know we're else to post I don't have enough points.Im using phantom 3 standard.
2022-2-9
CavemanSean
App doesn't open for me (Samsung S21 Ultra) it opened before.... so a recent android update broke compatibility.
Rather sad that high end drones like these don't work on high end mobile devices.
Unless DJI fixes this soon I think I'll be switching to another drone brand that actually cares about it's clients.
Older devices (I use a DJI P3A) are still quite amazing.
2022-2-14
ConnorSchulte
Flight distance : 261033 ft
Fix the fucking app it's been years!!!!
2022-3-26
Werner Beroux
Switzerland
I agree, fix the app, or make it open source and we will fix your .... Unless you're scared to expose something.
2022-6-19
djiuser_FugxAVk3nhzv
Trinidad and Tobago
App is still broken! I swear DJI is just like Apple.. terrible... Fix your goddamn app.. it's been 2 fricking years hoss what the hell..
2022-8-28
djiuser_QH3UfvcScpNS
I talked to Support today and DJI has no plans to help us in the short term. This was their response:
It is found that your mobile device is Galaxy 20 Android, and compatibility tests are required to be carried out. As there are many models that need to be tested currently, it cannot be resolved in the short term. We are really sorry for the inconvenience caused.
If you have an urgent mission, we recommend you to prepare a spare mobile device to carry out the mission, instead of using this device to avoid that the mission cannot be carried out due to compatibility issue.
We are sorry for the inconvenience caused to you. Thank you for your understanding and support!
So all of us with an Osmo or Phantom....we now have ourselves very expensive paper weights that we can't use. This sounds like a class action lawsuit just waiting to happen.
2022-8-30
