endotherm
Flight distance : 503241 ft
zzzanzzzibar Posted at 2-2 05:24
thanks for the answer.
Unfortunatly, even with the sticks asking to lower the orbit I can go under 5 meters (maybe you have a special tips ?).
was wondering how to avoid or cheat thoses limitations...
5m is a safety limit built in to the auto modes.
I'd suggest trying to find lower ground to set as your home point. Let's say it is 2m lower than the area you wish to orbit. As you get to your point of interest, you can set the auto-orbit at 7m (7m above your home, but only 5m above the ground at your point of interest. That should satisfy the application's insistence that it has to fly above 5m, as it has no way of knowing what the actual terrain is like at your target. Unfortunately you are out of luck if you are on a flat plain that doesn't have any dips or depressions nearby. I haven't tried this trick myself, but it should work. |
