DarthSLR
Flight distance : 1846716 ft
If USB mode is enabled, then, when connected to a computer via USB AND POWERED ON, it will serve ONLY as external storage.
In this mode, M3 shuts down other functions and thus consumes less energy.
The immediate side effect would be that you would not be able to run Digital Assistant 2 in that mode. So, if you ever need to run it, you'd have to uncheck that mode in DJI Fly app.
That said since you don't use DA2 that often, keeping USB mode on would help you to prolong your battery life. |
