fansfe82067d
Mine has arrived - and I love it - but...
- It's a great pity a cold shoe wasn't moulded into the side of it to accept accessories such as a mic.
- When attaching a 3rd party cold shoe between the tripod and the camera, the little locking pins get in the way of the cold shoe (which of course doesn't have the necessary sockets). It's a pity the pins don't retract. I'll have to improvise some kind of pad between the cold shoe and the tripod into which those pins can push.
- The remote control is designed to handle up to 8 cameras, but I suspect the number of users who will use that will be miniscule. However, when you turn on the remote, it starts hunting for extra cameras every time. When it finds the first one, a figure 1 appears on the display, and unless you then press the red button to stop the hunt, it will continue for 30 seconds. No big deal, but perhaps the button on the side should have been devoted to multi-camera use, rather than the device defaulting to expect multi cameras, which as I said will almost never be present.
- The lanyard attachment holes are so placed that you can't put the remote into the tripod if you have a lanyard attached.
Plus point - I could imagine using a bit of sticky putty to attach the remote to a car steering wheel, and then you attach the camera in the car out of reach somewhere, and you could control the camera from the steering wheel as desired. I'm sure many other such scenarios could be dreamed up. Given that many users are finding that the Mimo app no longer works with the Action 2, this way of having at least a degree of remote control is very welcome.
Wish list - I wonder whether a firmware upgrade could enable the remote to work with the Pocket 2 as well? Yes, I tried it and no, it doesn't pair. |
