fish sticks
New Zealand
Yes, it looks like we disagree. I think you are giving general advice regarding heat leading to wear of electronics (and batteries). I don’t think this necessarily implies that using the high temperature threshold will break the Action 2.
Here some info:
-the difference between the low and high temp threshold is small (5-10 degC)
-the temp threshold increases with a protective case made out of heat isolating material
-the high temp threshold is not available in EU&UK
-the camera probably doesn’t wear very differently in the EU&UK
-a pc component like a cpu can be validated to run for years at temps close to 100 degC
-the typical usage of an action camera prohibits using the camera for extensive periods of time due to limited battery and memory capacity |
