frankymusik
Flight distance : 27841053 ft
Labroides Posted at 3-5 23:20
I learned a while back that there's no way to get through to you.
I only respond to counter the misinformation you put out.
I can even understand why you speak of "misinformation"...
You are not at all willing to follow a precisely described path of experiments because you have not had any experience with GPS problems in "normal life". So far so good...
However, the problems discussed in the forum were precisely about the fact that the M3's GPS behaved "extraordinarily"...
You can accept that and you don't have to worry about it.
But until DJI finally presents a solution (remedy), it is allowed to share personal experiences and also to carry out experiments. This also "shortens" the waiting time for the fix from DJI, which will hopefully be available soon.
But if you ignore links like "https://www.gps.gov/systems/gps/performance/accuracy/" yourself, then no "insight" can be expected...
What do you mean, what should be understood by "atmospheric conditions" in that post...?
Or under the note "receiver design features/quality" to be read there...?
Well-designed GPS receivers have no noticeable problems in bad weather (e.g. clouds with ice crystals, in wintry conditions).
We all already know: A GPS receiver is not just the GPS chip and the associated antennas, no, it is also the associated software, including parameters (data that are permanently stored in the software) that the GPS chip uses for evaluation of the signals, with which the signal amplification, for example, can also be set (similar to a camera whose sensitivity can be constantly adjusted).
If you have not dealt with such things in detail (e.g. professionally), then you will find it difficult to understand this.
But to constantly claim that you alone (and maybe an additional clerk) know everything about GPS problems (especially in the border area), that's just unfair...
And since you are trying to slander me, for example by saying publicly that I wrote here that you should have your M3 inddor flown (for testing purposes), you are showing your spite. Not everyone who takes a quick look at such a discussion follows every statement made by both sides, and can therefore only wonder what is said here.
You shouldn't add slander that unjustly discredits others!
Just think about it!
