Tuxtard
Flight distance : 9975610 ft
Serbia
Hi guys,
Today I encountered "Propeller guards detected. Flight performance lowered to ensure flight safety (Code: 30154)" warning in the middle of the flight. First time i noticed this warning was at 13:30 minutes in flight and at that point I headed home and brought it back. After reviewing logs I noticed that this warning first appeard at 3:33, but it flashed so fast that I didn't even notice. It was a rather calm day. UAV Forecast showed low wind and gusts up to 25 km/h at 100m. I was mostly flying at a very low altitude where the wind was even calmer and it didn't "feel" windy. I did a more thorough inspection of the props and the drone afterwards, and did't find anything unusual.
Now, I am using Master Airscrew props and motor caps on this unit and I know that this issue might be related to this setup, but since this is not a new configuration and I've flown it like this for a while now (even with gimbal protector and ND filter on that I dindn't mount for this flight) and this was the first time this issue occured, I would like to investigate. I am hoping that someone can help me extract motor and other related values from the log so I can hopefully isolate and fix the issue. You can find the log here:
https://www.phantomhelp.com/logviewer/L0P7HTXSGCIWGJHJ186B/
Thanks.
P.S. Drone never had any crashes or hard landings. It was mostly landed and launched from the hand.
