Mats Bohlinsson
Flight distance : 1838077 ft
Sweden
0.1m is the resolution comming from the firmware. Unless you hack the firmware you can't get better than that.
Imu? good luck with that, The drift would be insane. The only way to read the imu is through parameters, and I think it's limited to 10Hz if you don't do it on the drone, which again need hacking.
I would opt for some kind of CV, if you need that precision.
