DJI Stephen
Hello there Scybe. I am sorry for the trouble this has caused and thank you for reaching out. In order to immerse you in the stunning first-person view, The DJI FPV is equipped with a single-axis gimbal camera with a maximum FOV of about 150°. Therefore, the DJI FPV Drone can take pictures when flying at certain angles. To the oar shadow, you can refer to the following methods to avoid this phenomenon:
1. If you need to take a first-person view lens, when the flying speed of the aircraft increases, the lens will be tilted up, and the lens will not take the propeller shadow at this time;
2. If you need to shoot scenery, it is recommended that you choose a suitable gimbal pitch angle, and control the attitude of the aircraft with a reasonable stick. After the repeated shooting, you can get the best angle video.
3. Turning on the image correction can also avoid large-area shooting of the blade;
4. You can also crop the video that contains the paddle shadow during the post-processing of the video
Thank you. |
