JJB*
Flight distance : 12225059 ft
Hi Labroides,
No need to look again ofcourse, thanks for the 'advice', but as you asked it friendly i did load the log again.
But your "failure of the drone" equals my "simple motor fail", both explaining an out of the normal failure for a DJI drone, so why the need for you to give me advice?
btw, in a general speaking ; directive writing doesn`t mean that the writing is correct, for newbies and non tech readers bit overwhelming mayby , as you would understand as a scientist.
Agree, we both do not know what happend, but if 2 motors were 'hit' slightly and both had difficulty to spin freely afterwards....
High amps could say something about the power draw, engines at high rpm uses a lot, or high amp to try to keep the motors at needed rpm if motor doesn`t spin freely.
Indeed no spinning or tumbling down but craft moved in a right turn down, see roll (more/less 'steady linear' 50 to 30 degrees right) and pitch drone angles and move data line. Move line does say something about the power distribution/rpm`s of the motors.
If al 4 engines equally down in speed bc of a FC fail, craft would move down in a forward movement.
cheers
JJB |
