Connecting Phantom 4 Remote with Apple iPad mini 6
7683 17 2022-3-6
Dutch799
Flight distance : 73871 ft
Brazil
I just purchased the Apple Ipad Mini 6 (with USB-C) to use with my Phantom 4. Unfortunately the Pantom 4 Remote does not connect with the Ipad Mini 6. I expect the Apple Ipad Mini 6 is not supported by DJI.
Any idea when DJI will support this Ipad Mini 6
2022-3-6
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. As per checking here, it seems that the mobile device that you had mentioned is not compatible with the DJI Go 4 app and the DJI Phantom 4. Therefore, we cannot guarantee that it will work properly with the app and the unit. We strongly suggest using a compatible device to avoid issues. You may refer to the link below for the list of compatible devices. Thank you for your kind understanding.
https://www.dji.com/downloads/djiapp/dji-go-4
2022-3-7
Dutch799
Brazil
Hi DJI Paladin,
Thank you for your super fast answer. Any idea when the Apple mini 6 will become a DJI supported device?
Regards,
2022-3-7
frandenrdennisfrantz.com
Flight distance : 4026 ft
Dutch799 Posted at 3-7 09:41
Hi DJI Paladin,
Regards,
I too would like to know if DJI is going to suppor the iPad Mini 6. I have 4 Phantom 4 pro and 3 Phantom 3 pros. Please reply soon and let us know if we must return this product.
Thank you.
2022-3-12
ash16
Mauritius
Hello. I am looking to buy an iPad Mini 6 to work with my DJI Phantom 4. has this issue been resolved? is it now a compatible device?
2022-7-20
djiuser_L87JMe0UYFMW
Flight distance : 2312756 ft
If you've got a Phantom 4 Pro v1 and an iPad Mini 6 that won't work together, I've found a USB A to USB C adapter and charging cord combo that will make it work. I've tried dozens of combos, and this finally worked! Links below.
Syntech USB C Female to USB Male Adapter Type C to USB A Converter Compatible with iPhone 13 12 Pro Max iPad Air 6 Apple Watch Series 7 AirPods 3 Samsung Galaxy etc Silver https://a.co/d/174caKg
Super Fast Charger Type C, 25W USB-C Fast Charging Block with 10FT Android Phone Charger Cable for Samsung Galaxy S22/S22 Ultra/S22+/S21/S21 Ultra/S21+/S21 FE/Note 20 S20 Ultra/Note 10 Plus/Z Fold 3 https://a.co/d/gBoeaDR
2022-8-30
Pimpmg
Flight distance : 700574 ft
The usb a to usb c adapter is right on!  It does work but did not work with the usb c cables you had the link too.
USB C to USB C Cable, INIU 100W [2-Pack 6.6ft] PD 5A Fast Charging Type C to Type C Cable, Nylon Braided USB-C Cord Phone Charger for Samsung S22 Note 20 iPad Pro MacBook Tablets LG Google etc. https://www.amazon.com/dp/B08J2HXYPH?ref_=cm_sw_r_apin_dp_M4GYXB02CXA8ZZ8X4HR2
I tried it with this cable and mine does connect to the DJI go 4 app I am going to try a drone deploy flight in a minute but it seems like it is connected fine…
It works!!!
2023-5-1
Shawgod
Flight distance : 5173104 ft
DJI Paladin Posted at 2022-3-7 03:08
I find that the iPhone 14 pro max running iOS 16 works just fine with it as well.
2023-5-2
Shawgod
Pimpmg Posted at 5-1 12:20
I just ordered the cable, I guess we will see if that works, I own the adapter.  I have been on so many wild goose chases trying to get this to work, I don't know what works anymore.
2023-5-2
Pimpmg
Shawgod Posted at 5-2 06:07
Me too this combo finally worked I wasn’t expecting it to but it worked for me and I’m really happy because my old iPad mini 2 kept locking up in the DJI go 4 app.  I hope it works for you too!  I had to look way back through my Amazon purchases to find the usb c cable I ended up using.  So I hope it works for everybody…
2023-5-2
DJI Paladin
Shawgod Posted at 5-2 06:01
Hi there, Shawgod. You may give it a try and download the DJI Go 4 app on your mobile device via our website and see if you can connect the app to your mobile device. If you experience any issues, please let us know. Have a nice day ahead!
2023-5-4
Shawgod
I bought this setup off Amazon and tried it out.  Unfortunately I couldn’t get it to work.  I tried a few other adapters I had sitting around and nothing would work.  The cable is a great cable.  3 year warranty and high speed cable for charging is a plus.  I just can’t get it to work with the DJI phantom 4 pro.
2023-5-4
Shawgod
DJI Paladin Posted at 5-4 00:50
I have a Apple product don’t I have to install it through the App Store?
2023-5-4
Pimpmg
I tried another usb c to usb c cable I had for a portable ssd I have and it worked too.  Is your controller fully charged?  And are you on the same IOS as me I think it is 16.4.1 also all firmware on drone and controller are up to date.  I uninstalled and reinstalled DJI go 4 before I tried this adapter and cable.  Also when you connect to the controller is the controller charging the iPad?  Or does it disconnect soon after you connect it?  Some of the cables I tried would charge the iPad from the controller for a few seconds and then they would quit.  I think the problem is the usb c cables they are not all alike.  I tried the one that came with my iPad from apple and it would not work.
2023-5-4
DJI Paladin
Shawgod Posted at 5-4 07:18
You may access the link and click the iOS version so you will be routed to the exact download screen of the said app. Hope this helps. Thank you for your continued support.
2023-5-4
Revealer Media
You need to remember that for those remotes, the USB C cables only work in one direction. I have a Phantom 4 Pro V1 and iPad mini 6 and I got it to work using the USB A to USB C adapter and USB C cable. But you have to try it both ways. It will only work in one direction. Once you've worked out which direction works, mark the cable for next time!.
2023-6-14
k9cops
Iv just bought iPad mini 4, so I guess that want work ether even tho DJI says it will
2023-7-31
DJI Tony
k9cops Posted at 7-31 05:43
Hello there. The iPad Mini 4 should work. You can use the following link to check: https://www.dji.com/ch/downloads/products/phantom-4-pro. Under the DJI Go 4 icon, please hover your cursor on the "View supported devices" There you can see the iPad Mini 4 on the list. Have a great day ahead.
2023-8-2
