Battery so tight
IRMMZ 1
Flight distance : 294249 ft
So, my P3P battery fits too tight. How tight? So tight that we need 2 people to remove the battery. One holding the drone and another pulling the battery. This is a new battery with only 4 charge cycles. And compared to the other battery with 17 charge cycles, it is looser. The new battery and old battery have no difference. I can see no wear and swelling. I tried the silicone lube but to no avail. It gets to the point that I have to use a popsicle stick to pry out the battery. It starts getting really tight after the last grey label. Does anyone have solutions because this is a pain in the arse.
2022-3-9
JetSam
Flight distance : 3617244 ft
Welcome IRMMZ 1 Are we talking about an original battery?
2022-3-9
IRMMZ 1
JetSam Posted at 3-9 10:45
Yup, both are original batteries.
2022-3-9
Mark The Droner
Flight distance : 2917 ft
2022-3-9
IRMMZ 1
Mark The Droner Posted at 3-9 15:29
https://www.youtube.com/watch?v=XIperEc05Ls
Tried those, no use. Works on the other battery though.
2022-3-9
Mark The Droner
IRMMZ 1 Posted at 3-9 15:58
What you're describing is not normal unless you have a swollen battery.  Since you say the battery is new and not swollen, it might be an aftermarket battery that's made not quite to specs.  Or there is some defect with your OEM DJI battery - or the drone battery compartment too - such as a burr on the plastic or a slight warp.  But that's very rare.  Here are some more ideas:
2022-3-9
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble that this has caused. Can you please send us a video sample showing the issue for us to further check and isolate it for you? In addition, kindly please provide us the serial number via PM so we can check the battery on our end. Please keep us posted. Thank you
2022-3-9
IRMMZ 1
Mark The Droner Posted at 3-9 16:48
https://www.youtube.com/watch?v=bzHizVWBpxU
I found the solution, it is to pull it out with ALL my might and with my hands dry. That seemed to have fixed the problem
2022-3-11
