No Original Thought
Flight distance : 1364209 ft
relaxosmo Posted at 3-30 07:48
Thanks, again, i know all of these informations.
Only i cannot create the same nice, sharp, noise-less picture from DNG what the JPG has!
Can you write your workflow? I even see strange moire effect on a building's roof pattern, which is invisible on jpg!
I'm no expert on raw processing - far from it, I'm just starting out with that myself - but your JPG image also has the moire effect in the lower roof. The reason it is much more onvious in the DNG image is that the JPG is so soft the moire effect is hidden.
Moire effect is a result of limitations of the sensor, not the file format, so this is precisely what you would expect.
(And for anyone reading who doesn't know - the image above labelled as DNG is in fact also a JPEG, but presumably a JPEG created from the DNG manually rather than the JPEG created by the Mini2 automatically when shooting).
I've briefly played with a couple of applocations for processing raw images and SO much is possible that I ended up with either poor results or just using a preset which completely defeated the point of using raw.
That said, I always take raw as well as JPEG where possible because I do intend to learn how to process raw properly to get the best image possible looking as close to how I want it as possible - rather than it looking like somebody else (camera manufacturer or software developer) thinks it should look. |
