Buc_Caneer
Flight distance : 400902 ft
South Africa
Sean-bumble-bee Posted at 3-12 08:13
I can see reasons for their not doing it, namely safety of others and dogs. Also I'd bet some folks would claim it was DJI's fault that the drone crashed into some that low.
I could see reason in a 5m floor but not much below that.
If you want to do it let the drone reach 15m and start towards home then bring it down to 1.5m.
Sure. I also doubt that DJI will consider this, but if you don't ask, you won't get. My argument to DJI is that I can manually fly at 1.5m and bash into things and even with the current 15m limit of RTH, pilots are still flying into obstacles.
When RTH is initiated, one can change the orientation of the drone, but it returns to the 15m limit on the way back when you force it lower.
Drone Hacks have come back to me. They cannot help.
The closest work around is setting up a simple mission in Litchi, but there is quite a bit more admin involved.
Thanks for your input, though. |
